ADP multiple keys
station32
The Radio Guy
Augusta Me
I was trying to program my XTS2500 with multiple ADP keys and i can only get one to work at a time in the radio. Any ideas. I am running the latest version of firmware 15 and using the CPS version 16. I set it up in the personality and selected secure strapping and the appropriate key. I don't know what i am doing wrong.
Thanks In Advance,
Joe
bezking
On the Road
I see that your radio has both hardware encryption and software ADP. Are you trying to use software crypto or the hardware UCM?
station32
The Radio Guy
Augusta Me
I am trying to use software i dont even have the hardware module in it but i am trying to find one. But ya i am using the software adp.
gary123
did you load seperate keys into the key field?. You can also set up the menu item KEY to allow you to switch between keys.
I would doubel check the starppping and selected key for each channel. I would also recomend enabling the display key nae feature so that you can see the key name when you select it.
station32
The Radio Guy
Augusta Me
Is what i did is put three different keys in the key list. That i am using three seperate freqs/channels and for secure i use select setting and i use the correct keyin the personality. I have no idea it seams to alway be using key one no matter what key i tell it to use.
n3obl
ØAES-1056
PA
you need a option in the menu to select the different key or select a different key for each channel.
Frank
