What about interwacn with full spectrum scan enabled subscribers going around pinging every single system it can find? Where I live almost every county has their own countywide system, often time I've seen radios from counties away trying to register. Will that cause issues? Anyone want to chime in on that?
No impact at all. Annoying to watch ZW, YES. And you don't necessarily need to have FSS enabled.
If radio was programmed correctly and kept up to date, really no need for full spectrum scan. Or if radio was programmed correctly and kept up to date, even with FSS enabled radio would not need to use that FSS. FSS does have it's place, like during build outs for example.
Side Note.... many programmers do not realize that the order of the CC list matters in the radio. Our Local and region sites are at the top of the CC list. The the radio checks each entered CC list one by one down the list. By ordering the list, keeps radio's from bouncing around sites when turned on. Radio reg/aff much much faster.
I can't tell you how many times another agency brought me a radio, turn it on.. and takes for ever to reg/aff to the site or bounces around a few sites. Or even worse the radio is set to ignore adjacent site broadcast, FSS is on and CC list not prioritized. Makes for a poor user experience.
Sounds like that may also be part of the issue your seeing.
