mproy
- Joined
- Aug 11, 2010
- Messages
- 9
- Reaction score
- 3
Hello
Disclaimer: I have 15+ years of Motorola portable radio programming experience, but I am fairly newbie to Repeater programming (had very good success with XPR8300 and MotoTRBo 14).
I recently purchased a XPR8400 repeater from a local radio shop (via ebay as it was cheaper believe it or not) and program it using CPS 2.0 2.21.61.0.
After some tweaking of hang time (as we could hear for almost a full second some dead noise after tx) to 1000ms, I have had great success reading, configuring it for an FM pair of frequencies (as assigned by ISED Canada). The portable radios were BPR40.
question 1 I then copied channel 1 to channel 2 and modified it to respect the second set of authorized ISED Canada frequencies.... BUT the repeater would not "trigger" on RX (TX from the portable radios). I moved position 2 to 1. Wrote and it now worked... but no longer the "old" channel 1 now in position 2. Should I understand the XPR8400 will only work with one set of FM channel at a time and the second channel would be for DMR only? Or did I miss something?
Question 2 When I used the second set of frequencies with cp200 and cp200d radios in analog mode, on several occasions but not everytime, the repeater (via RX it got maybe) it would transmit garbled audio long after the user transmitting had let go of the trigger. Almost like if the key had been stuck open... This occured with two different users transmitting (not related to only one radio) among a group of 8-10 users. Could the radio side programming be causing this behavior? Or should I look at the repeater side? Is there a self test or a test I can perform on the repeater to ensure it is "up to snuff" and not defective (obviously buying from a reputable company I assume it was ok as not listed bad, but...?)
Thank you in advance
M.P.
M.P.
