AFS to HEX conversion
BJ_NORTON
Las Vegas
I have a list of talkgroups for an edacs system that I have been monitoring with T4Win. I am going back through the Talk group screen and changing the unknown to their proper name. When I try to display the talkgroups in AFS format, T4win shows the wrong TG number. example TG 05-121 displays as 05-101. this doesn't seem to be a uniform off by 20 conversion though. When they are displayed in Hex though, they are the correct number. I know you can use the scientific calculator to convert, but that would take forever as I have 150+ TGs. is there a simple formula I can copy into a spreadsheet and then convert my talkgroups, or do I have to do it 1 by 1?
BANDIT
Gainesville, Ga
If you have the hex numbers for the id's in a etrunk *grp.txt file there is a small program called E2A.exe.
It will read the *grp.txt file and put out a new file with the AFS id's. Check the downloads section.
Converting AFS to decimal. Take the AFS number as AA-FFS where
AA - the first two agency digits in range of 0 to 15
FF - the middle two fleet digits in range of 0 to 15
S - the subfleet digit in range of 0 to 7
decimal value = AA*16*8 + FF*8 + S
Use your calculator to convert the decimal result to hex.
05-121 = 5*16*8 + 12*8 + 1 = 640 + 96 + 1 = 737 decimal or $2E0 hex.
Does that match what you have?
-rick
dave3825
Suffolk County NY
BJ_NORTON said:
I have a list of talkgroups for an edacs system that I have been monitoring with T4Win. I have 150+ TGs. is there a simple formula I can copy into a spreadsheet and then convert my talkgroups, or do I have to do it 1 by 1?
I take the t4win.xml and open it in excel and then extract the ids and paste them into win 95 and convert from afs dec hex etc.The only thing is you can only do 20 at a time.I wish it did like 100 or so
xusmarine1979
Louisville, Ohio
I don't know a whole lot on this particular subject, can you use dec on the Pro-96, and if so how? Also what are the differences?
