Aftermarket Antennas
ScanWV
Eastern Panhandle West Virginia
Any ideas on a good aftermarket all band antenna? Have a new pro 106 and have a 800 mhz antenna but it lacks in lower bands. Ideas for portable, mobile and base antennas are appreciated. Looking to upgrade in all aspects. thanks
thewenk
Idaho DB Admin
Eastern Idaho
A shorter antenna than the the RH77 is the Premier(Pryme) RD-8 that IMO is almost as good as the the RH77 without the length. I have used the RD-8 and its brother the RD-9 almost exclusively as an all band antenna for several years. I also have the RH77. While doing a search, I found it for a really great price of $14.95.
http://www.frys.com/product/2591811
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=3177
http://www.pqdvd.com/deals/pqdvd1/index.php?browse=prod&site=4&node=657&p=1
Here are some tests that include both the Rh77 and the RD8.
http://www.strongsignals.net/access/content/opi_ant.html
http://www.strongsignals.net/access...pe=display&rtype=rev&class=ant&num=003#080799
Dave
Phoenix Arizona
Over time I have observed that the RH77 has a loyal fan base. It must be pretty darn good. Maybe pick that up for VHF / UHF stuff, and keep the RS 800 antenna handy for the 800 mhz range.
thewenk
Idaho DB Admin
Eastern Idaho
Quoting from Strong Signals testing performed in 1999 that can be found here:
"Comparing the scores for the 4 longest, non-telescoping models puts the W881 in the lead with the RH-77CA and RD-78 back one "point", and the RD-98 back 6 points. So, for all intents and purposes, the W881, RH-77CA and RD-78 perform identically. Considering the latest pricing, the RH-77CA rings in at $25, the W881 at $35, the RD-78 at $23, and the RD-98 at $25. Comparing price versus performance makes the decision between these pretty easy"
Dave
Wahoos4Life
Rixeyville Va
Dave
alittle confused, so would that be a good antenna? or no?
thewenk
Idaho DB Admin
Eastern Idaho
The W881 and the RH77 are equally good in performance according to this test. So buy whatever is cheaper, which at the time of this test was the RH77. Just check prices today, if price is an issue, and decide for yourself. The W881 is a good antenna, but somewhat expensive.
Dave
Wahoos4Life
Rixeyville Va
Dave
What radio was it tested on by chance do you know?
id be using it for the 106
thewenk
Idaho DB Admin
Eastern Idaho
As is explained in the test report:
These readings were taken over two very similar days (clear, low 60s, moderate humidity) between the hours of 3 and 10 PM ET. My Yupiteru MVT-7100 was the test radio used for all measurements due to its wide frequency ranges, adjustable steps sizes and receive modes and more importantly, it has a well-calibrated S-meter (compared to the AR8000, HS200, IC-R1 and IC-R10).
As previously stated, the thing that matters is that all the tests were done on the same radio.
Dave
