Ahh yes, the ST2
AuntEnvy
Central New York
I know it's been covered but... ;)
And I know it works great on low, vhf hi and 400, but what's the latest on 800 mhz for this thing? Has there been enough time for people to try it in this range? Are people finding it useful or no good at all?
I've read a few of the articles here and they seem to digress towards coax, other frequency coverage, mounting etc. So basically this would be a "poll" of sorts.
Thanks folks :)
LtDoc
Oklahoma
I don't own one so take this for what it's worth.
If an antenna isn't specifically designed for a particular frequency range it will not 'work' as well as one that is designed for that range. No way around that. There are some 'lengths' that will 'work' for almost any frequency range but how 'well' they 'work' will always depend on the user's definition of 'well'. A metal window screen will 'work', but...
See where that's going? There's no such thing as a "one size fit's all", doesn't matter if you're talking about antennas or shoes... (except for 'flip-flops'!)
- 'Doc
Bucko
Marietta, Ohio
I have used the ST2 for at least 3 years now and the 800mz area works pretty good for me although I am on a high hill. Of course it comes down to line of site but I am hearing what I want to hear with no problem. It is Split 4 ways with an amp plus filtering. It compares pretty close to my old CM 5094A which I still use. I am not using the stock coax but is RG6. This antenna has been talked to death and you will probably get other views am sure.
vagrant
ker-muhj-uhn
California
- 'Doc
I own one and agree with this all the way. Compromising may result in hearing nothing at all. Besides, what works for me at my location, means little at your location and what you're trying to receive. If you want/need to listen to 800, that's the tuned antenna you should use. Whomever is transmitting on 800 Mhz probably isn't using a 27 Mhz antenna. I use an ST2 for some things, but I am willing to compromise versus having an antenna farm. Good coax is a concern as well, if the run is long. Get it up high!
AuntEnvy
Central New York
Thanks doc
- 'Doc
Yes, I indeed realize the "one size" rule. ;)
I guess I'm basically wondering if it will be of any use for a local 800 system whilst still being used for other bands.
AuntEnvy
Central New York
Indeed bucko
Has any other antenna been discussed more...? ;)
And I'm sure I will get the "try it and see" reply sooner or later as well, to which I know I will end up doing anyway. :)
I just hate to go through all the work if it will indeed not pick 800 up at all.
Thanks for your input though. Sounds like I should be able to get 800 reception locally.
AuntEnvy
Central New York
Thank you vagrant
Ahh yes, the ole compromise... ;)
I'm rather certain my location in relation to the system will be of no real concern since I/it will be centrally located.
Nonetheless, I have the feeling I will be installing 2 antennas. You know how we are! :)
