Air refueling route error?
D
DaveNF2G
Guest
I tried to plot some northeastern aerial refueling routes on Google Earth. The coordinates that I used came from AP1B (described in other threads).
AR-205 and AR-212 turn out to be identical, according to the DoD document. Is this correct? Also, is there really a bend in the middle of this route?
:confused:
MWillyG
Southington, CT
Ar-205 & Ar-212
Dave,
In reference to your second question, yes, there is a "dog-leg" at a point that is roughly at the mid-point, I believe, of the track.
D
DaveNF2G
Guest
Thanks! Your map looks exactly like what I ended up with when I plotted AR-202, 206, 212, 609, and 631.
TinEar
Glen Burnie, Maryland
Dave, that map provided by MWillyG above along with the frequencies used for AR ops, including all the new freqs, can be found in the Wiki.
http://wiki.radioreference.com/index.php/Mid-Atlantic_AAR_Tracks
There is so much good info in the Wiki but it's often difficult to find unless you stumble upon the correct search term to be able to find it. I knew that map/freq page was there but it took several tries before it popped up. For that one I finally tried 'AR Tracks.' It's actually listed as "Mid-Atlantic AAR Tracks" although it contains much more than the Mid-Atlantic area.
