Airband Antenna
rayneeny
Eastern Passage,Nova Scotia,Canada.
I have a BC346XTC,my question is what would be the best antenna for picking up the civil airband.
Attic cannot be used and it would need to be setup inside the house.
Thanks in advance.
Ray
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you are using the handheld in a fixed position - say on a desk -- then constructing a simple ground plane, mounted as high as you can get it near an outside wall - will work just fine...Mike
rayneeny
Would that portable antenna be a wilson 900-901 62"whip?Asking as i saw that advertised on a site in canada.
The DPD Antenna looks very nice indeed and sounds like it will do the job.
Will look into the groundplane also,thanks guys.
Ray
questnz
Ray,
Watson 901 as described, it is actually very short. Also I have good results on air with Watson WSMA 801 and 881 as well as Diamond SRH77CA none of them advertised as an Air antenna but work well.
Actually with NON scientific tests I could not tell the difference between Watson 801 and 901 they look the same length and size the same !? How 901 is "tuned to Air" but 801 specified as a "wide band" is misery to me. However, W801 is my favorite out of the house and out of the vehicle and travel antenna.
StevenS
San Diego
Hi Ray,
Without a doubt I would recommend to everyone the Centerfire VHF Airband Base Station Scanner Antenna. I use mine all of the time. You can see my personal review of the antenna I just wrote clicking the link below to my website.
I really do not know why I did not write that review sooner. I have owned my Centerfire antenna for about 15 years and the thing is still in awesome shape and works as well as the day I first installed it. I would recommend that particular antenna to anyone who is into picking up aircraft transmissions with the highest gain. I routinely pick up ground control communications at an airport more than 18 miles away! It is an awesome antenna to say the least. Again, you can read my review of it at the site listed below, if you are interested. I also provide a link on my site letting you know where to get it for the cheapest price as well.
nanZor
Typically, for a handheld that is wideband and prone to overload, a duck actually tuned to airband (and not just a claim!) can make quite a difference.
For airband monitoring with my handheld scanners, I use the antennas from my commercial airband transceivers as they are narrowband in nature as compared to the typical 2m/440 amateur ducks and whips. Depending on where you live, that can make all the difference. So instead of an 18" wideband whip, the 6 inch airband-tuned duck actually works better on a wideband handheld scanner.
One suitable combo is the Icom FA-B02AR airband duck, used along with the bnc/sma adapter that should have come with your 346xt. The Icom is bnc. You should have no trouble finding the FA-B02AR. Just don't let the tip touch your body as it will detune the antenna.
If you want a direct connect to SMA, then Yaesu makes a few airband ducks from their commercial airband transceiver line that would do just as well.
Some makers make the *claim* of being airband capable, when in fact they are just bog-standard 2-meter amateur antennas or actually tuned to the commercial vhf 150mhz band instead with a dinky little airplane icon stamped on them. Beware - they know you don't have the equipment to verify it.
I also second KA3JJZ's recommendation of trying a simple quarter wave ground plane first before springing for something commercial like the Centerfire.
22 inches of wire soldered to the center conductor of a bnc or S0-239 connector, and at least two radials (4 are better) of 22 inches soldered to the shell of those connectors and angled down just a little bit can do the job indoors. This is a very simple yet effective DIY airband quarter-wave groundplane.
