In Sentinel, click on "Edit Profile" (4th icon, top row). In the window that opens, click on the tab marked "Scan Selection" (it may already be open). You will see your Favorites Lists. The lists you want loaded in the scanner should be "On" in the "Download" column. If you want them to load when you power up the scanner, they should also be "On" in the "Monitor" column.
Next, select the tab labeled "Quick Keys Status". If you want the lists to scan when you power up, the box number corresponding to the FL's QK must be checked.
Close the small window, and click the "Save" icon (3rd icon, top row), then Write to Scanner.
Service Types was going to be my next suggestion.In the favorites lists that are not transferring, make a list of the service types for the channels and talkgroups. Go to the Profile Editor and the Service Types tab. Make sure that the appropriate service types are checked to match the channels and talkgroups.
What are you trying to monitor? Need city, county, state, and agency. With that, we will be able to look it up.
Texas, Upshur County, County Systems. There are numerous agencies listed under "Texas Wide Area Network (TXWARN) Project 25". In the database I can see Texas Wide Area Network (TXWARN), but not Texas Wide Area Network (TXWARN) Project 25 and before I screwed things up, I could.
The highlighted agencies will not "write to scanner" but the others will.
Have you considered a subscription to RR? Then you have updated info transferred to sentinel for you. Greg
Then why do I have a subscription?
