Alpha Tag delay
Ret_Batt_Chief
Windsor,ca
There is a slight delay in Alpha tag displaying on my feed. Using Proscan. Is there a setting somewhere where that can be adjusted.
ProScan
Software Provider
Ontario, Calif.
Wht type of scanner are you isng?
Are you using the source client and/or web server feature?
What media player are you using? See if there's a network buffer size option that can be adjusted.
Ret_Batt_Chief
Windsor,ca
Using the source client. Using a USB sound card. BCT15X. I will look for a network buffer.
ProScan
Software Provider
Ontario, Calif.
I was referring to the output and not the input. I was thinking that if you were using a media player such as WinAmp, or VLC then perhaps the network buffer size could be changed. Scratch that question because I see now that Broadcastify uses a HTML5 player and Advance Player. They used to let the user select an external player.
How much delay are you seeing? If using the HTML5 player, try using the Advanced Player. You should see the latency decrease. My experience with the Advance Player is that the latency is about a second or less.
No setting in ProScan to adjust the audio / text tag sync.
{edit} I have experence with the Advance Player because my ProScan Web Server webpage uses it too.
