HBdigital1
- Joined
- Apr 2, 2002
- Messages
- 79
Hello, finally got a replacement unit from Grove(other one was "sick"). Anyway, I entered 2 different TSYS into working memory, in scan lists 1 and 2 respectively, and labeled one as "OC countywide" and the other as "OC south". When I elect to scanllist 1(OC countywide), the lower part of display toggles back between this label and OC south; however, when I monitor only scanlist 2(OC south), the display shows ONLY OC south! NOt sure why, when scanning system 1(with system 2 OFF), the display toggles between the 2 systems, ALTHOUGH the monitored transmissions are ONLY from scanlist 1. Before I pull any hair out and have to use Minoxidil, wanted to see if any of you have any ideas as to why the display does this funny activity, although the radio reception is accurate on that one system. thanks in advance!
