Alternate Streaming Port
dwh367
Amateur Radio Operator
Owensboro, KY (Daviess County)
Is there another port available on the servers that we can stream to? The outgoing traffic on port 80 seems to be bogging down the incoming traffic on port 80. Never had that problem when I was running my own feed on port 8080.
GordonE
Scanner Radio App Developer
You can also use ports 8000, 8080, or 8500. I doubt that using a different port number will have any affect unless your ISP is metering outgoing traffic on port 80, the alternate port numbers are typically used to get around firewall problems.
dwh367
Thanks for the information. I'll try one of them just to see if it makes any difference.
