Analog scanner
mjbjr
Macon,Ga USA
I provide the Macon,Pd feed,and someone else is providig the Bibb sheriff an Fire feed.i was gonna get an analog scanner and seperate the feeds so that fire and sheriff are separate.Any suggestions? I dont wanna spend alot if i can help it.and is it possible to run 2 diff feeds from one pc?
rmiller818
Marietta GA
You could get a used one fairly cheap. If that is not your thing, checkout Radio Shack, they had some good deals on pro 163/163s not long ago.
As for running 2 feeds on 1 PC, absolutely (I do it now) you just need an additional sound card. You can run as many feeds as you have inputs basically. Some even have stereo feeds where one scanner is on the left channel and a 2nd scanner is on the right one.
