Another Bluetooth question.
Robotech2112
Carbon Unit.
Lenawee/ Monroe Line, Michigan
Has anybody ad any luck with pairing a G5 with "stealthy" ear buds? I need a stealth solution so the Unication brand bluetooth device and others like it that are mostly outside the ear and are obvious...are out. Thanks.
K6LEH
Oakland, CA
These work with the beta firmware, v1.40,, but they arent made anymore.
No beeps when it picks up a transmission, unlike my Plantronics Voyager Pro. Which also pair with my G5
DewAddict
Michigan
My Galaxy Buds+ also work. No beep, no cutoff of the transmissions. Just got my G4 today and it was the first Bluetooth device I tried.
shadow925
San Diego, CA
I use these and find them to work perfectly. Only $30 also which is good.
One odd thing I noticed recently was after connecting my G4 to a car's bluetooth (connected but didn't get audio) I was unable to connect my earbuds again. The solution was to factory reset the G4 through the menu option. After that they paired fine again. Must be some sort of software bug putting the G4 bluetooth into a bad mode.
K6LEH
Oakland, CA
I did some research into multipoint paring with wireless earbuds. There are only a couple of options in the “earbud” category.
The Jabra’s, which run over a $200 generally.
It seems that ”earbuds” are considered consumer grade, vs something like a Plantronics Voyager, which was designed for business use.
As I mentioned before, the Plantronics connect perfectly and I can use my iPhone and G5 at the same time. Meaning, I can answer my phone with the Plantronics and the audio from the G5 will be muted. After the call is completed, it switches back.
Calls always have the priority.
Except for vehicle pairing, more things work with the G5 than not (as far as bluetooth devices), IMHO
