Another CDM1250 question - Startup channel and power draw
avascan522
Los Angeles County, CA
I recently purchased two used CDM1250's, S-split, and have been going through programming and testing.
I'll start with the programming question: Every time I restart the radio, it reverts back to channel 1, or my first personality channel. I would like it to start-up on the channel I last had selected. I've seen other programming software where this is an option, but I don't see it on the Professional Series CPS. Advice?
Power consumption: It seems that these radios are pretty "thirsty" for voltage. I misplaced my inline power meter, so until a new one comes in the mail I can't read the DC amp draw, but from testing with a multimeter, these CDM's (both) bring down a 12V battery from ~12.7V charged to around 10.7V in standby, not receiving, not transmitting. Is this normal voltage drop? I don't nearly see the same drop from any ham radios I own, or even an XPR 4550. In general, it seems like this type of draw would be a deal-breaker for a vehicular install.
I appreciate any advice or observations you have about what I've described.
K2NEC
NA
With programing you have no choice. It will always revert back to personality 1 after writing a codeplug by default. You are thinking of on powerup. You can tell the radio to power on the last selected channel.
nokones
Sun City West, AZ
The only thing I see in the CPS insofar as an option to recall, is an option for "Recall Last Selected Menu".
I had a temporary company car for a short period of time in between my permanent company cars that was equipped with a CDM1550 and I don't recall (no pun) if I had that problem but our primary channel was Zone and Channel 1. However, there were times that I had details and had to use other channels but I don't think I had to set the channel every time I shut off the radio and turned it back on. Of course, that was a few decades ago.
PreferredCustomer
North Prairie, Wi
If your battery voltage is dropping immediately to 10.7, you have a bad cell in your battery.
WA0CBW
Shawnee Kansas (Kansas City)
Check all the DC cable connections from the battery to the radio. That includes any fuses and holders. Look for corroded battery and chassis ground connections.
Bill
avascan522
Thanks for the feedback.
Last comment- DC cables and connections are good, no blown or bad fuses, and the battery is a new-ish 18Ah SLA battery only 2 year old and maintained above 12V its whole life. I've only used it on the bench to test radios temporarily, also while I program.
CPS- Yes, I see "recall last selected menu." I will select that and see if it fixes the problem on startup. That is what I was looking for - if I turn the radio off on 'channel 3', I would like it to turn back on on 'channel 3' after I restart it. Programming re-start isn't the goal.
