So after my pet fence issues, my RFI issues were very close to being resolved. The last two weeks however have been frustrating, but I have been a little busy... so I didn't have time to run around looking for the source.
The good thing is that I found the sources, but the bad thing, is I have only myself to blame. (Okay, so I'm kicking myself now.)
I just thought I'd share the quick details:
A couple of weeks ago, I was listening on AM and heard really bad AC hum. This is very common noise while in AM but it was never this bad. It seemed worse from 2-10 Mhz...
A simple check - I flipped a circuit breaker. Noise was nearly gone. Okay, so it was something IN the house. Great. After some initial trial and error, I couldn't locate it.
Finally, I had a light day today. I grabbed the Sony 7600GR and set it for 2000 Khz. I extended the whip and walked toward the other side of the basement.
Low and behold. The FAX machine! It was plugged in to the AC outlet but the phone wire was disconnected (so it wouldn't auto answer.) Disconnecting the AC plug revealed an immediate drop in the signal strength. (PS. I just picked this up a few weeks ago from a friend. He was getting rid of it, so I took it off his hands.)
I still had some AC hum. Hmm. I swept the downstairs - nothing else. I went upstairs and found the culprit. A touch lamp! It was one of those small ones and it had been unplugged. If memory serves, I probably plugged it back in to do some reading. (It's next to the chair.)
GRRR!
Okay, so I'm taking these devices and throwing them in the garbage.
:twisted:
What gets me is how these things generate RFI w/o even being on! BTW, switching on the lamp to its highest setting was like cranking up a the RFI generator!
On a positive note, now that I have a known source of RFI, I am going to buy one of those cheap RFI plugs and see how well it works. If it works well and cuts the RFI, then I'll probably get a few of them for around the house.
PS. The AC hum was S9+20 and now there's ZERO hum. The noise floor is around S2-S3 but nice and clean white noise.
GRRR!
