dynamixone
hello all,
I have been searching through the countless threads on discones and coax. My question is theoretically how much can I gain upgrading what I have just using the antenna that came with the SDS-200.
My Scanner: SDS-200
My Antenna: Tram - 1411 on 20 ft of top rail outside my home.
My cable: 35 ft of RG6 quad shield and N Connector and BNC on the ends.
What do I scan, a little bit of everything but mostly P25 in the 700 range and conventional freqs in the 150 and 400 range.
My results: I have been connected for a couple of days to the setup that I used to use to play with SDR dongles. I am getting good range for what I need. 30 miles around me that was what I thought was very clear. I decided to run the analyzer and start watching the RSSI on the scanner more closely.
I was getting 95-101 RSSI from local P25 traffic from the scanner read out.
I know the rg6 is not ideal so have been working out running Times LMR-400 but then tested with my supplied antenna that came with the SDS200.
WOW, a lot better. all local stuff is getting low 70s RSSI from the supplied antenna and anything that wasnt "clear" is crystal now. More distant stuff is around the RSSI I was getting from local channels.
My main question is do I go through the cost and effort to run the LMR-400 to my Tram 1411 or will I be chasing that as well and need to replace the antenna? The cheap antenna it came with is doing much better. I'm afraid I will drop all this money and how much reception is expected to be gained? I want a broader antenna to be able to scan more things.
Is my antenna hurting me more than my cable?
I know this is more broad question but up to what I really want to listen to but figured I would through it out there for some opinions.
thank you for your time.
My Scanner: SDS-200
