ANOTHER TRX-1 Newbie With a Programming Problem
harleymac1
Central Indiana
Y'all are probably getting sick of us and our programming problems but I got one I could use some help with. I have 9 scan lists named within EZ Scan at this time. I wanted to be able to (if I understand correctly) to be able to isolate my local PD, SD, and Fire EMS at any time in scan sets so they are in their own scan list. I also made my state police in one and made a list for the county I work in. This is where the problem started. 8 of the 9 scan lists imported my selected channels just fine but the county I work in, Johnson County Indiana will not import correctly, I select all PD and FD channels but the only one it will import is Johnson Memorial Hospital ER. Can anyone give me any ideas? I use the same process trying to set this scan list as I did the others but just can not figure out what I am missing. Thanks in advance for any advice. My last scanner I owned was in 1996 so it has been a long time.
According to thr RRDB Johnson County uses the Project Hoosier SAFE-T System are you trying to enter these? I don't see any reason they wouldn't be added, they aren't encrypted (according to the data base). I do notice Johnson Co SO is using NXDN, does your TRX-1 have the most recent firmware update giving it NXDN capability?
When I tried they imported fine, see bottom two.
