An antenna is an antenna, period, so as for it being "a scanner antenna" the point is somewhat moot - it's either going to be a good
receiving antenna or it's not, and in that respect since all scanners do is receive that's what's actually relevant. I wouldn't guess it's bad at what it does but given the design and the purpose of the antenna - to be mounted on top of vehicles that tend to have a respectable distance off the ground itself and also to be using the vehicle's roof panel or surface to work as a ground plane to some degrees - that would mean if you're using it in a home situation mounted inside then I'd say no it's not going to perform as well as something else based on the design itself.
I've yet to encounter one of those stubby dome like antennas that really works worth a damn on any hardware period whether it's receive only or RX/TX capable but that's just my experience.
As noted, something as simple as this dirt-cheap homebrew 1/4 wave ground plane you can make yourself in a few minutes with some coat hangers and an SO-239 chassis mount like this could be dramatically superior:
