Outtolima
I have a RCI 2950 dx .I dont transmit in anything other than the cb bands but enjoy listening to all else (im unlicensed at this point).I had this radio mounted in a semi that had a flat top sleeper and used a single 6ft frances antenna with very good results.
I recently purchased a new truck with a condo style high roof bunk and am in the process of installing all my gear but am wondering if the single antenna configuration will work as well on the new truck as on the old due to the higher roof.The general opinion seems to be that a dual antenna system will be superior.The roof is made of some type of plastic but has a wire mesh that runs through it for structural integrity,
I would rather use a single antenna system as i also have a scanner antenna and cell antenna with sattelite radio soon to follow so real estate on the mirror brackets to mount another antenna will be very scarce.Mounting anything on the roof itself is out of the question.
Any tips or advice re cb ,scanner, cell antenna installation , coax lengths etc will be greatly apppreciated. Thanks in advance.
