Antenna conector 90 * BNC
chazcarly
Ringwood NJ
Is there a good place to look for a BNC adapter that is 90* and one end connects to antenna conector and the other is BNC to go to scanner, I dont want the wire to go straight out the back of the scanner, I dont have a lot of room where the scanner sits. I need the wire to come in from one side at a 90* turn?
Voyager
PACNWDude
Tessco may have them,look at their website. They have all the odd ones, Males to Male 259 barrels, reverse pin sma, things like that.
www.tessco.com
Where I get all of my odd electronic parts.
chazcarly
Ringwood NJ
I'm not sure I've ever seen a 90 degree adapter with a BNC male on one side and an SO239 on the other. You can't just use the angle connector with a common BNC to SO239 adapter?
UPDATE: Well hot dang I take it back...
BNC Male to UHF So 239 Right Angle Coax Coaxial Adapter OPEK at 7089 New | eBay
There is also this for about half the price if you don't mind the jumper...
UHF So 239 Female Jack to BNC Right Angle Male Plug Jumper Cable RG58 20cm Wire | eBay
VOYAGER !! YOU ARE THE MAN ,
I just purchased 2 from ebay, I have been searching for weeks and could not come up with anything ?? No pictures came up in Google searches, nothing HOW DID YOU FIND THIS ? I guess i was not using the right terminology ?
Thanks for everyones responce....
Voyager
I searched ebay.com for "angle adapter UHF BNC". (there are lots more with the other genders - BNC-F to UHF-M)
