corneileous
I hope this is the right part of the forum to ask this but anyway, what I have is a 2017 Freightliner Cascadia and for those that don’t know anything about how the factory antenna wiring on these trucks works, what they did was, there’s like a 4 foot antenna mounted to each side of the cab towards the back of the cab behind the doors and then they ran a coax from each antenna mount to a spot right behind the speedometer and the tachometer behind the steering wheel into one single male PL-259 connector that threads onto the input side of a multiplexer….
…..on the other side of that multiplexer, there are two female BNC antenna jacks where one output goes up to the headliner where the spot is for the CB and the other female BNC antenna jack on the multiplexer is what goes directly to the antenna input for the AM/FM radio and the whole thought behind all this is, is so that you can have just two antennas that you can use to pick up your radio stations and be able to use your CB……
Well, being that their factory antenna mounts- due to the crazy way they designed them, doesn’t even let you properly ground the antenna mount itself(not the part the antenna threads into) and the coax to the chassis ground through the sheet metal cab, this is another hurdle(besides the multiplexer) that also keeps you from being able to achieve anywhere even remotely close to a good SWR. Not to mention the fact that if it wasn’t for the multiplexer being bad enough, you don’t even have the ability to properly tune each antenna individually because like I said before, both antenna cables are soldered into one PL-259 connector. And then to top it all off, they didn’t even use one continuous string of coax to get from the factory antenna mounts to the multiplexer.
They ran the cable down to the floor from the top of the cab and then ran it underneath the door threshold and right there behind each kick panel where the cable comes up to go into the dash, there’s also another connector right there which, if memory serves me correctly, it’s whatever the proper name is for basically a mini PL 259 connector. And also not to mention, where the coax comes from the multiplexer to go up to where the CB goes, they ran that cable behind the plastic A-pillar cover and basically right in the middle of the A-pillar, there’s, I believe, a BNC connection there as well….lol.
So as you can see, the way they added this in here, if you was to use the factory set up for your CB, your range would probably only be less than 100 feet.
Well, after running my own coax straight to my CB from a modified CB antenna mount that you can get at any truckstop that’s actually bolted to the part of the factory antenna amount that’s bolted to the side of the cab, I got all that straightened out and since I’m now basically only using the passenger side antenna as only my stereo antenna, I’m wondering if I could actually increase that reception if I was to completely remove the multiplexer and just crimp a female BNC connector to that cable and then just take the cable coming from the stereo and connecting it directly to that if that would actually help anything or if I could get by with just cutting the factory coax that used to come from the driver side CB antenna, tape it up real good and then just put a female PL 259 to female BNC and just hook the stereo antenna cable straight to it that way.
Sorry for the long post but I just felt the need to explain exactly how this is so that you guys know what I’m not dealing with.
