Antenna Coupler
mikebires
In regards to my previous article about using an 800 mhz antenna and a Diamond Discone.....
Is there a splitter out there which will allow me to use this combination to feed it into my BC796?
Al42
Long Island, NY, USA
Be aware that if you use a 2-port coupler you only get (at most) half the signal on each scanner. 1/3 for a 3-port, 1/4 for a 4-port, etc.
And, if you get a coupler with more than 2 ports now, to allow for future expansion, you still have to terminate all the ports.
N
N_Jay
Guest
Now, for those who are new:
Loosing 1/2 the signal is a 3dB loss, which most people can not even detect.
The question is; what is better IN TOTAL,
the 3.5 db splitter loss with the gain from the added 800 MHz antenna?
OR
Where you are now?
70 feet of RG8X is about 8.5 db of loss at 800 MHz
70 feet of LMR400 is about 2.5 db of loss at 800 MHz
70 feet of RG6 is about 6 db of loss at 800 MHz
At 800 MHz, you cable become MUCH more important than your antenna.
mgosdin
Kissimmee, Florida
At 800 MHz, you cable become(s) MUCH more important than your antenna.
Distilled wisdom from N_Jay, very good. Definite keeper.
Mark Gosdin
mikebires
Thanks N_Jay
Thanks for your help. I appreciate it. So, if I'm getting this right...here is what you are suggesting.....
First, change out my cable to LMR400 and see if this helps with the Diamond Discone.
If that doesn't work, then move on to splitting the signal with a splitter.
Thanks again
N
N_Jay
Guest
Re: Thanks N_Jay
Thanks again
I would move to a better antenna, since the splitter is going to loose you 3.5 dB on both sides.
