Looking for input for best antenna to utilize on or in a vehicle for SDS100?
Thank YouOne of the best mobile antennas out there for scanner use. Larsen NMO150450800 LARSEN ANTENNAS NMO150450800 Larsen VHF/UHF Mobile Antennas | DX Engineering
Thank YouThe Larsen NMO-150/450/800 that twjr80 linked to above is a pretty good option. It's been around for quite a while and is well proven.
They've since released a newer model that has a base spring and a more flexible whip.
Pulse / Larsen Antenna - Tri-Band Whip Antenna, NMO - NMO150/450/758 - Tessco
Pulse / Larsen Antenna's tri-band mobile antenna. This antenna is thoughtfully and thoroughly designed with all the needs and concerns of those in the public safety sphere in mind. The high-value whip provides excellent range and coverage while remaining small, resilient, and aesthetically...www.tessco.com
-or-
Pulse / Larsen Antenna - NMO Tri-Band 150-174/430-520/750-870 MHz - NMO150/450/758SF - Tessco
NMO, Tri-Band 150-174/430-520/750-870 MHz, Super Flex Whipwww.tessco.com
-or-
Pulse / Larsen Antenna - NMO Tri-Band 150-174/430-520/806-960 MHz - NMO150/450/800SF - Tessco
NMO, Tri-Band 150-174/430-520/806-960 MHz, Super Flex Whipwww.tessco.com
I'm currently running that antenna on the roof of my work truck and my personal truck connected to Harris XL-200M multiband mobile radios and they work very well.
I've also been playing with EM Wave antennas, and finding they are just as good, if not slightly better than Larsen. I've been spec'ing these out at work as I exhaust my stock of Larsen antennas:
E/M Wave, Inc. - Tri-band 150-162/450-490/763-870 MHz Ant - EM-M43002 - Tessco
EM WAVE Tri-band 150-162 / 450-490 / 763-870 MHzIP67 Rated NMO Roof Mount Whip Antennawww.tessco.com
The EMWave is a bit more chonky than the Larsen. I prefer the sleeker design of the Larsen on my personal truck. Both antennas perform identically and are of similar designs. EMWave has a nicer base sealing design, but either works fine.
I'd happily recommend either the Larsen or the EM Wave.
The linked prices will be high, so shop around, you can find them cheaper.
All sorts of choices. Best one, (IMHO), is the one with three magnets, and either the SO-239 or NMO in the middle. Usually $39-$59 with cable and PL259.Just wondering if Larson makes a magnet mount? Thanks in advance !!
