emtunderwood
- Joined
- Dec 8, 2007
- Messages
- 153
- Reaction score
- 11
Ok, I have a question or concerns. I have gathered some information and I'm posting this too the masses for some help and clarification on a conversation that I had with Sinclair and Comprod in the past few days.
First, I know I've posted about repeater problems and what not. It has came to conclusion that we have antenna and coax issues, as well as, desense issue, not seen at the ground level but it is happening at the antenna level.
Commscope makes our ava5-50 and they wanted me to check the ohn resistance at the ground level. I followed the steps for the ohm probes the outter ground of the hardline was zero and center pin was 19ohm with a mild wind and upto almost 40 in stronger winds. Commscope believes there is a bad connector at the antenna or on on the jumper to hardline. So, ok gotta get that fixed too.
However, speaking with Comprod and discussing antenna options they are suggestion a 884-70 in bi-directional pattern or 872-70 facing our main coverage area and leaving everything behind the antenna as unity gain. The concurred with commscope as there is definitely something concerning with the ohm loss and increasing impedance with increased winds.
Speaking with sinclair and discussing our problems and potential solutions. 1. move our antenna from 3ft off the tower to 6ft. and dropping our antenna from 305ft which is 567ft. AGL down to 190ft. and 460ft AGL or farther but woulding drop the AGL below 400ft. He stated that VHF likes to run along terrain instead of where it is now up in the air with no obstructions and according to his calculations the beam isn't coming close to terrain for 33mile away completely overshooting our area. He stated that the Commander 220-3BN at 8.1dbi where ok if we were in flat land and trying to talk out to 60mile mark or farther. He stated that the dbi needed to be about 5-6 and since our ERP is rated at 180watt and 280watt EIRP that we need to saturate our area and would bring the coverage area in closer to 20-25mile mark. He was explaining that down-tilt was not neccessary in this situation due to terrain. He suggestted SC281-HF3LDF and SC251HF3LDFD. He suggested this be placed 6ft from the tower, with the area with least coverage behind the antenna because it is going to null out. Sinclair also stated that we maybe trying to push too much over a mountainous area and needed 2 sites.
A local radio tower/communications company is telling us this is all BS that we need to install a DB-224 at the current height and we will talk better than we ever have and they only require a 13in stand-off. Well, I'm not sold on that with as many as they have to replace here in mountainous WV and the ones they have installed have worked worse than what they have replaced.
So what is y'alls take on this and thoughts on a solution.
Thank You
Thank You
