Antenna issues
blueangel-eric
Emporia, KS
Hey guys....
Some VERY helpful info you have provided!
I've also been in touch with one of the engineers @ Larsen. I tested the resistance between the mounts and the body of the vehicle; I got about 38 Ohms, and he says I should be getting under 1 Ohm. In other words, there is no ground plane. His suggestion (shy of drilling 6 holes in the roof) is to fender mount them. Larsen makes a high freq NMO mount that is identical to the regular NMO mounts, but the wiring is completely enclosed. He suggests that if/when I move everything to the fender that I replace the cable assemblies/mounts with these enclosed mounts.
Thoughts?
what about the rust or corrosion? wouldn't that make resistance too?
yorkphotog
Toronto, ON, Canada
According to the guy I've been speaking to at Larsen, the rust under the mounts is no big deal. He suggests I remount all of the antennas to the fender of the truck using NMO high frequency mounts. The design of the HF mounts is what's different -- the wiring is completely enclosed, so exposure to weather is no big deal. The 38 Ohm resistance basically says there is currently zip for a ground plane. Opinions?
