Antenna Mount For UTV
boy7777777777
Arkansas
Where do you buy antenna mounts for UTV's at? Wanting to put a radio for GMRS use in my UTV and can't seem to find any sort of mounts for nmo antennas. What does everybody use?
ladn
Many of us here have had good results from the Antenna Farm. They offer decent prices and a wide selection.
Depending on your particular install situation, you may have to look around for the specific mounting hardware you want, but buy a quality NMO mount with cable (Larsen, PCTEL, Maxrad). Avoid no-name brands and cheap Chinese brands like Tram and Browning (these used to be to American brands, but are now just name licenses).
You'll also want to have the proper antenna design for your vehicle, as some UTV's don't have adequate ground planes.
I have a Polaris Ranger and run a VHF mobile radio in it.
I looked at the available options for antenna mounts. Most were overpriced and used low quality Chinese NMO mounts/cable. I chose to build my own.
I used a roll bar light mount and fabricated an NMO mounting bracket out of some 1" wide aluminum bar stock. I used a surface mount NMO mount that I took off a Laird magnet mount.
You can get the UTV antenna mounts from places like Racing Radios, Rugged Radios, etc. Problem is they use the cheap Chinese mounts. That might be fine for some, but it's not my style and I have the stuff to fabricate my own mounts.
Here's a link to them from Rugged Radios. I think they are WAY overpriced...
You can get the UTV roll bar light brackets a lot cheaper:
Get a —QUALITY— NMO mount, not the Chinese crap. Stick with Laird, Larsen, etc. Tram, Browning, and any name you cannot pronounce are usually poor quality and have poorly installed connectors.
Avoid the temptation to use the NMO fender mounts. They are thin metal and won't stand up to the beating.
And as @ladn said above, you need to have the right antenna. The roll bar mounts often won't make a good ground connection, and the offset nature of the mount results in a poor ground plane (if it even has one…). I'd recommend going with a 1/2 wave style antenna, they'll tune up without a ground plane. That'll save you headaches.
I'm running a 1/2 wave VHF antenna with a spring base. I think it's a Laird. I've had it on my UTV for about 3,000 miles and it has been through some pretty rough stuff. I've hit tree branches at 40mph and even have a permanent kink at the end of the whip. The coil/mount/spring is still in good shape. One of the areas we ride has some low underpasses under railroad tracks/highways where the UTV barely clears the overhead. I've had the whip bent over a full 90º right at the spring with no issues.
You can try the Cheap Chinese stuff, but the money you'll save at the start will quickly get lost when you need to keep replacing antennas. But then again, if all you do is putt around slowly on nice smooth trails, it might be just fine.
This is the UHF equivalent of the antenna I'm running:
Laird seems to have some issues with their coils cracking, but mine has been just fine.
At work, I spec out all Larsen antennas, and in 30 years, they've never let me down.
I have recently started using EM Wave antennas, and I'm seriously impressed. I have them on both of my personal vehicles and am considering switching to them at work. I'd endorse them if you are looking for a solid antenna:
Pay a few bucks more for the good antennas now. It'll save you money and headaches down the road. Avoid the Chinese crap.
I believe the stuff Rugged Radios sells is Korean, but agree that it is way over-priced.
Yeah, looks like they changed from last time I looked. At one point they were selling what looked like rebadged Tram/Browning.
The current stuff is still overpriced, and you can get quality name brand stuff cheaper. I think their demographics are people that don't know anything about radios and want to buy it all as a package deal.
boy7777777777
Arkansas
Thanks for all the helpful info. I'll definitely stock with a quality antenna. I was hoping to not have to fabricate a mount but looks like that'll be the better bet.
Well, you can do this strap on mount. But it requires using the NMO mounts that use the 3/8" hole. That's not a big deal, they just are not quite as common as those that use 3/4" holes.
Or, you can use this one, that is more expensive, but uses the standard 3/4" NMO mounts:
I'm a bit of a cheap skate, but I like solid gear, so I tend to go with the better antennas/mounts, and then fabricate the stuff I need. Nothing wrong with buying something off the shelf if you don't have the shop equipment or time to fab your own.
trooper430
He is the on I ordered.
Waiting to get it and try it on my Kawasaki Mule Pro FXT.
Marchboom
North Idaho
Yep.
There some things that you should just pay more for to get the good stuff. Life is too short to go thru the frustration of a poor antenna. You're only going to get pissed off and buy the more expensive antenna any way. Remember, only rich people can afford to buy cheap stuff.
