Consider cable routing.
Consider cable length, more distance = more feedline losses = less performance.
Consider cable type. Cheap coax = more feedline losses = less performance.
You want short cable runs and high quality coax.
You really want to consider proper grounding and lightning protection (required by National Electric Code, and just plain common sense). Olathe Kansas, this should be very high on your list and not something you ignore.
Ideal setup:
Antenna up high and in the clear, or as close as you can SAFELY get it.
Away from all overhead power lines.
Ideally close to existing home ground rod.
Close to your radios so you can reduce feedline losses.
Consider placement of lightning protection device where coax enters the home, and easy access to ground rod.
Keep other occupants (wife) happy.
If you live in an HOA community, you really need to think carefully.
Keep neighbors happy by being reasonable and not putting up something that falls on their home.
If you are new to the hobby, consider that this won't be your only antenna. Plan accordingly now and make life easier down the road.
