What would be a good antenna with gain for 159 MHz to receive farther away signals
Multiple directions, I'm not really experience on antennas on what to getAre all the signals you want to receive in one direction, or are they in many different directions?
If in one direction (pointed at a distant city) a directional antenna can be a good choice.
If they are in different directions around you, a base antenna with 3-6dB of gain can be a good option. It really comes down to your budget, as you can get antennas with a few dB of gain for anywhere from $100 to $2500.
Would it pick up local 800 mhzI've got one of these up at a radio site, connected to an AIS receiver. It's been a good performer and has stood up to the elements pretty well:
This'll give you 3dB of gain. It's not a heavy antenna, so while it will need a solid mount, you might do fine with some 1" pipe.
What does more gain do, does it help pull in farther signalsNo, not very well. That's a VHF antenna.
If you are looking for multiple bands, then you'd want to look at dedicated base scanner antennas. Not my area of experience, though.
Exactly.What does more gain do, does it help pull in farther signals
It can be used with a scannerExactly.
Would you go with a dual band antenna, but the one you have is what I mostly listen toIf you are asking if the antenna can be used with a scanner, yes, any antenna can be used for a scanner. You just need to find one that covers the frequencies you want.
That's something you need to decide. If all you need is VHF and budget is a concern, that Siro is a good choice.
If you expect you'll need VHF and UHF, and you want good performance, you'd want to use a dual band antenna designed for the frequencies you want to listen to.
What antenna are you currently using? Is it outdoors and if so, how high is it?What would be a good antenna with gain for 159 MHz to receive farther away signals
CenterfireWhat antenna are you currently using? Is it outdoors and if so, how high is it?
5/8 λ Ground Plane base station antenna for land and marine service. It works on the frequency range of 135-175 MHz by using the tuning diagram enclosed. The matching coil is DC feeded for a perfect protection from the static discharges. GP 3-E is made of non-corrosive aluminium and assembled on a very strong base of die-cast metal to get the maximun robustness and the best performance. Tuning is easy by following the attached directions. Does it have to be cutThat is designed for the amateur radio bands, and won't work as well up in the frequencies you want to listen to.
