Good all-around antenna
I read your post about wanting a antenna for your scanner. Well, to receive all the frequencies you want, it depends on how weak of signal you want to pick up and how you will be using the scanner. If this is to be a base scanner, then the bigger the better (to a point). I would strongly reccommend you build a couple antennas and put them on a switch (if you are a serious scanner). First I would figure out the most common frequency that you want to scan. Then build a 5/8 wave for the center of that frequency (300/f*39.37*.625). That would give you good results. J-poles are good antennas, but a moxon might give you better receive. Also, the larger the material (copper pipe versus wire) will give you better bandwidth. (If you were to get into Amateur Radio, you'd learn stuff like this.) If you were to make a series of Moxon antennas, you could make it look like a piece of art and it would load up on the frequency that each is tuned for. The great thing about a Moxon is that if it is placed vertically, it will pick up the horizontal signals as well. But if you are only going to use this as a mobile scanner, then maybe a pocket j-pole is your best bet.
