Skysho
Just to add a little to the discussion. A couple months ago I used the quad in my attic that is attached to a rotator and directed it towards a repeater signal. I calibrated the rotating quad with a compass to the controller. I pasted a compass rose on the face of the controller since it wasn't designed for small increments. Using the Mk4 Sniffer I turned the quad toward the strongest signal and noted the degree reading. Using Google Earth I drew a vector line on the map from my house toward the repeater signal using that degree reading. I sent a screen print of my map to the repeater owner to see how close I was. He said I hadn't gone out far enough. He shared with me where the repeater was located and the address. I extended my line and found his repeater. I missed it by about 400 yards and its 17 miles away up in the hills and I'm not direct line of sight. There is a one small hill or I'd be a direct shot to the repeater. Now it was either crap luck or one can get some fairly good readings. I don't think I could have gotten that accurate of a reading with my Doppler. I'm using the Sniffer and a loop when I get close to a transmitter anyway.
