Anyone reckon the height of this tower?
TrainsOfThought
Land, waters, sky...an entire universe to monitor!
DelMarVa Peninsula
Contemplating research for a tower option for multiple band-specific scanner antennas (directional 6db gain yagi rail band w/rotators X2, omnidirectional air band discone & marine band = 4 antennas) vs individual roof mounts. This pictured older in-use tower in my rural DelMarVa Town has a height clearing medium size yard and horizon trees as well as the highest hill elevations in my Google Earth radio base-to-target path. Possible installation would be right next to the house office/radio room, lowest loss coax...
Anyone care to guess the height of this tower? Concrete base; one attachment point at the rain gutter and no guy lines.
MUTNAV
Thanks everyone.View attachment 125063
Great Mmckenna beat me to it.
My complete guess is 45 feet or so.... The real way to do it is to see how many sections are connected and guess the size of each section. (ie 4, 10 foot sections or so)...
I wouldn't try and copy this instillation though.... Just because I don't like it (doesn't look strong).
Do we get a prize if we guess right?
Joel
MUTNAV
The other option for the geek in all of us is to use a protractor and move away from it until you are sure that the top of it is at a 45 degree angle to the ground (assuming a level ground), then measure the distance you are away from it, that'll be the height.
Keep the base of the protractor level. You can kind of do it like this (from the new air force survival handbook).
Joel
MUTNAV
Trainsofthought has to be the one to post the winner !
(C'mon 45')
Joel
MUTNAV
ok... how about its looked at this way.
1 story is about 10 feet, the building has 3 levels of windows (well 2 and one with a vent (above the nearest door), there is then another level, above that, and the tower is higher than that.
Joel
wtp
Port Charlotte FL
muynav had it kind of right with his first post, but,
if you use the 45 degree thing at eye level, you then have to add your eye level to the height.
i would say disconnect it and lay it on the ground, but you want the height, not the length....:LOL:
popnokick
Northeast PA
There are other questions lurking behind the original question. The OP didn't mention it, but what is the reason the OP wants to know the height? Several possible answers to that:
- Doing potential range calculations for one or more of the antennas
- Figuring out how much coax will be needed when the tower is moved and reinstalled
- Figuring out how big a trailer (or how many loads) will be needed to move it from where it is now to the new location
BTW - Did y'all forget your HS trig? This is a pretty straightforward right triangle problem using the tangent angle and the opposite and adjacent sides of the triangle. You can be any distance you want from the base, but just need to know what the distance is (and you'll get a more accurate tangent measurement if you're a little farther away than, say, 10ft).
Remember "SOHCAHTOA" the Native American tribal leader who invented trig ;) Just kidding, but the SOHCAHTOA thing is a mnemonic to help you use a right triangle to determine unknown lengths / angle. It stands for Sine=Opposite over Hypotenuse, Cosine=Adjacent over Hypotenuse, and Tangent=Opposite over Adjacent. Sorry for the lecture... I forgot they don't teach mathematics in school anymore.
MUTNAV
With a 45 degree angle, you don't need the trig, but as was mentioned, add your eye height (and adjust for any difference in height that occurs over the distance).
The height might be needed for permitting purposes.
OR, concerned about the FCC or FAA new tower height rules for things over 50 feet, although they don't apply for towers next to your home.
Like I said though, I don't like the installation, doesn't look secure enough and I'd hate to hurt a house for a tower.
Joel
MUTNAV
Um... Trains of thought.... care to make some measurements, we have a matter of pride here to deal with ! ! !
Although thinking about it, he was the one asking US for the help figuring out the tower height :(
Joel
TrainsOfThought
DelMarVa Peninsula
And the answer is.....four 10 foot sections and appears a slightly shorter top section = 48 (50) feet.
It appears MUTNAV was closest at "45 feet". The prize (per bearcat) is the satisfaction and huge THANKS! of helping out a fellow enthusiast visualize said towers in the field for THEIR property, multiple antenna spacing (see popnokick suggestion), possible in-Town or County permitting (if any...next on my list). pardon-me-could2.jpg
prcguy
Is that the actual known height of each section or are you guessing? The tower is a lower cost unit and common for TV antenna installs, could be 8ft sections for easier and cheaper shipping. Something like a Rohn 25 would be 10ft sections, but thats a more substantial tower.
It appears MUTNAV was closest at "45 feet". The prize (per bearcat) is the satisfaction and huge THANKS! of helping out a fellow enthusiast visualize said towers in the field for THEIR property, multiple antenna spacing (see popnokick suggestion), possible in-Town or County permitting (if any...next on my list). View attachment 125083
TrainsOfThought
DelMarVa Peninsula
There were (25) 24"/2 foot cross sections total...5 per 10' long section and the math added up. I was able to see the joints between the separate 10' sections most of the way...a bit squinty for the last 2. It's an old building and the tower looks like it's been there a while. I agree with you and MUTNAV it appears NOT the most robust tower with only one stabization point to the building half way up...but then it's downtown crowded amongst other multi story buildings and the base is located in an alley vs out in an open field. I can see what you guys are getting at that a 50' tower at my residence at the edge of Town, surrounded by other homes in the development would require a more robust structure and supports...I'm surrounded by cornfields to the east; typical subdivision other directions.base station.JPG
