Anyone seen this???
b1100mac
Premium Member
Corvallis, Montana
While charging one of my G-5’s I have seen a “Charging Error, Battery Overheated, disconnect charger and reset unit”. This only seems to happen on one radio, and I get it on the base and the cord. Granted this is Arizona and its in the 90’s here in the garage but only does it on one radio. Stumped...Ray has said the (soon to be released) new firmware address’s some charging issues,,hope this is one of them. Any one else ever seen this?
APX8000
Sarcastic Member
AES-256 secured
I’ve only seen it once when I left it sitting in the car in the south Florida heat. After I let it cool down in the AC it went away.
LEH
Yorktown, Virginia
Wonder if it could be the battery type. From what I understand, early units shipped with a Lithium-Polymer battery and there were some issues with them. They are now using a Lithium-Ion.
Though it is a bit of a hassle, you may want to check which batteries you have in your units. If they are all the same, well disregard everything past "Wonder..." :D
You may be able to get the battery replaced under warranty, I've seen that mentioned, but don't hold me to the fire if they don't.
IAmSixNine
Dallas, TX
If you have several, and one is acting up. I would reflash the firmware.
