Anytone Anytone 5555Nii Different MIC ?
Sector46
dothan, al
Does anyone have any info on any mic which would
be compatable with the Anytone 5555Nii Transceiver ?
This may require an adapter, if so advise if 4 or 6
pin to RJ45 . IF You have a SCHEMATIC of the 8
PIN RJ45 5555Nii Side . Please Post. Would make
it very easy for MIC Changes since the radio can
be programmed for electret or dynamic elements .
OR Maybe Nothing can be done , Either way ADVISE
Thanks, Dave
prcguy
Thanks, Dave
Most power mics will work and you can crimp on an RJ45 connector on many of them. I have a base and mobile D-104 with RJ45s on mine. The key to installing an RJ45 is to use the EZ type connector where you can pull the mic wires through holes in the end of the connector before cutting and crimping.
bharvey2
The EZ RJ45 crimp on connectors are surely easier to use than the older closed end style but beware of the the older two piece ones. Those are a major PITA to use. I've only seen those for CAT6/CAT6A though.
Sector46
dothan, al
OK Thanks . I just ordered the 4 pin adapter from WALCOTT
and SITE SAYS FOR Anytone 5555 SPECIFICALLY...
I just don't wanna see any smoke, if I plug something else in / Hi.
