Anytone Anytone 878UV II Plus Programming Help ... band errors, TX freq errors, help?
FireMedic658
For reference, I have been programming Moto, Kenwood, Vertex and Harris radios for my fire department for years. I have been programming the Ailunce HD1 radios for a few years, for members to use as their personal non-issued radios. I have programmed analog conventional and P25 Phase 1. I understand how this is supposed to work, I think the radio may just have a software issue from the factory at this point.
How do you program p25 into an HD1?
n1moy
Plymouth Co, Massachusetts
Two questions about the AnyTone AT-D878UVII PLUS and D878UVII V3.02 CPS referencing the "Channel Information Edit" panel.
1. "TX Permit" setting has 4 options;
- Always
- ChannelFree
- Different Color Code
- Same Color Code
The "AT-D868UV/D878UV CodePlug Programming Guide" says, "Selects PTT transmit criteria – typically Same ColorCode" I have seen code plugs that use both the "Same" and "Different" options. Requesting a better explaination of the options. Also the best choice for a DMR repeater.
2. "DMR MODE" setting also has 4 options;
- DMO/simplex
- Repeater
- DCDM/Double Slot
- DCDM TS split
I have been unable to locate an explaination of these options in the Programming Guide. I have seen sample codeplus using both the simplex and repeater options. Which is the correct option for a DMR repeater?
Thanks,
AF1UD
- Always
- ChannelFree
- Same Color Code
- DMO/simplex
- Repeater
- DCDM/Double Slot
- DCDM TS split
Thanks,
1. A ColorCode is like a CTCSS/DCS tone. It must match to key up a repeater. Depending on how the repeater is programmed you may want same or different, but 99% of the time it's going to be same.
2.
