Anytone Anytone AT-5888UV USB port
jnojr
Chandler, AZ
This radio has a USB type A port on the head. I'm told it's for programming. But the programming cable I have from Anytone plugs into the same RJ45 jack as the mic. So, if this is a second programming port, what cable does it need? Just any USB A to USB A?
rf_patriot200
Freeport, Illinois
Low current devices can be used from the USB-A Port on the left side on the AT-5888UVIII, which is the Tri-band version of your radio. As you've noted that USB-A port is not for programming. I think my manual says it's Not operable, even though it IS.
jnojr
Chandler, AZ
"Operable", as in it provides 5VDC (or is it 3.3?)
