Anytone AT-6666 High SWR on 19...intermittently
amoking
Echo
Collin Co, TX
All,
Yesterday on a run from Dallas to San Antonio and back I was getting intermittent 'high swr' on 19. VFO is in fact 27.185. I was using the 'DW' function which scans 17 and 19 in my case. If I keyed on 17 I was at 1.0, 19 was 'hi swr'. A while later and this morning, 19 was back to 1.0. My coax/connectors are perfect. I have no rx issues.
kc2asb
NYC Area
Did you check the antenna itself for anything loose/broken? If everything does check out with the antenna and feedline, it does call into question the accuracy of the radio's meter, as per @DeeEx above.
K4EET
Chaplain
Severn, Maryland, USA
Could be an intermittent open/short between the radio’s transnit RF circuitry and the antenna tip. Does channel 17 or any other channels exhibit high SWR intermittently while transmitting? Does the high SWR indication occur when sitting still with the motor off (no vibrations) or does it only occur while moving? In addition to using an external SWR meter for troubleshooting, also consider swapping out the radio itself.
amoking
Echo
Collin Co, TX
It's peculiar because there is NO consistency. Currently it's at 1.0. Earlier it was 1.4 then HI SWR across all channels. My install is sound. May send it out to get checked. Happens driving, idle, truck off.
Unscrew the antenna and make sure the NMO mount is clean/dry. Make sure the little tab under the coil is not crammed up too high.
Unscrew the whip and make sure it's clean. Reinstall and make sure you put a bit of torque on it.
Make sure the set screw is tight holding the whip in place.
I've run across intermittent issues like this in the past, and it was usually one of the above items.
And, yes, check the coaxial connector. If you are using any adapters, suspect them heavily. They are common failure points.
amoking
Echo
Collin Co, TX
You're my Yoda, Matt, so I just tried that. Connection was physically sound and the coax is sound...you know the build.
There was some dielectric grease accumulated in there so I cleaned both sides. SWR currently at 1.0 and I hope it stays there!
