Anytone AT-778UV / Retevis RT-95 : Test Mode to lower UHF squelch threshold?
g8tzl2004
I have a Retevis RT-95 VHF/UHF 25W mobile radio.
The Retevis RT-95 is also sold under the Anytone AT-778UV name and others.
The radio is working well but the minimum user adjustable squelch threshold (Level 1) is still too high for RXing weak but copyable signals on UHF. I need to press and hold the Monitor key to hear weak signals. On VHF, the Level 1 squelch level is more or less OK.
I want to slightly lower the UHF squelch threshold (at Level 1) so that the squelch opens on weaker signals. I often do this with my commercial radio collection where the squelch threshold is usually set relatively high for commercial users.
I am aware that its possible to access "Test Mode" and this is usually done to enable wideband RX and TX. I presume the same "Test Mode" can be used to adjust various parameters such as the squelch threshold.
I wonder if anybody knows exactly what to do to lower the squelch threshold using Test Mode? Maybe there is a RT-95/AT-778UV service manual or a list of what can be done in Test Mode? I've searched the internet but can't find anything.
It might also be possible to align/tune the radio (including the squelch threshold) using programming software?
Falcon9h
I did that with my 878's. After tweaking with test mode, still too high. Between Anytone and Radtel, no one can get this right.
g8tzl2004
radio.carstenbauer.net has an excellent list of all the 878 alignment parameters.
The UHF squelch threshold is adjusted using parameter 19 SQTHU (60-134). The parameter value is increased to lower the squelch threshold. Apparently there is no improvement in lowering the squelch threshold above 115 although some users do report an improvement above 115.
Anybody know if a UHF squelch threshold of 115 (or slightly higher) still results in very weak UHF signals being missed?
I read that some users have been using the wrong parameter ( Squelch Tail Elimination ) when attempting to lower the squelch threshold.
I wonder if there is a similar list of Test Mode alignment parameters for the RT-95/AT-778UV?
