Anytone AT5555N
Dovebar1
Post Falls, ID
Looking at radios on Amazon.
Anyone have any info on this radio?
Any reviews from anyone on this.
Looking for radio that can do 10 meters possibly operate repeaters and other modes.
Thank you, Jim.
slowmover
Fort Worth
If this version is the one referenced then search under QT60 as the RADIODDITY nomenclature is that which is most used.
Probably (100) or more posts here on RR where it is mentioned.
— This was the groundbreaking radio model in AM/FM/SSB w/NRC + adequate power in 10/12M for mobile back in 2022.
I’ve several thousand hours with mine in 11M after conversion done.
You’ll find links (reviews) and experience cited.
Since then are a host of similar radios above & below it in price & features.
Dovebar1
Post Falls, ID
Thanks for the info. I am looking for a radio that can do 10 meter repeaters. If it does 12 meters, that is a bonus.
If this does cw that is good to. Since this was made there are newer radios which I will research.
Thank you, Jim.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
The Qt60 Pro has CW mode but no key input in the rear, you may have to make a cable to do it via the front panel mic jack PTT. I can tell you though that this model in particular is more updated than the Anytone 5555N II. This model has rx audio on the mic jack to allow for a single cable for digital sound card modes, outlined in an extra user manual available on the subject
Thank you, Jim.
. I've done plenty of 10M FT8 with mine. They also made the weather receiver tunable to anything in VHF so you can monitor 2m with it or public safety stuff in FM. The tx audio and rx audio are excellent and the radio was spot on freq out of the box. I can't say i've ever been more pleased with an 'export CB' in this class, most make terrible ham rigs. This does ham and CB (with mod) both excellently.
raindancerob
can a CW key be used using the same method on the Anytone version ?
