aor 2002 and 300a
rayzor_uk
just bought these two radios
2002 reads 10khz out so i have to take 10 of freqs added lucky only 20 mem channels
can i put this back on freq without special tools cause it is a smashing little set
Aor 3000a what software is avalable i use butel on 8200 is it avalable for 3000a or is ther others
cheers
rayzor_uk
cheers m8
picked them up on google beforei asked just hoping someone new of any others that dont show up on search engines
thanks
morfis
Yes there are others...mostly defunct and long gone or else stupidly expensive pieces of software aimed at government usage.
morfis
bagmouse7 said:
There is a procedure here that describes how to do an AR2002 frequency alignment.
A couple of other good tips for the radio are shown as well:
http://www.aoruk.com/2002bull.htm
I was well aware of the procedure but very much doubt the OP has the equipment or technical knowledge to be fooling around inside the radio!
rayzor_uk
cheers bagmouse verry helpfull
will go further into it carnt do no harm aslong has i put it back has it was
cheers
morfis
cheers
You are wrong. At present according to your post the display is offset by 10KHz. It's not difficult to adjust your working to accomodate this. If you start adjusting the alignment it is extremely unliikely that you will get it back to the original correct alignment without the correct equipment.
If you just start to adjust things then you are likley to end up with a totally useless radio and highly unlikley to be able to adjust back to your pre-meddling state.
Your money and your choice of course.
rayzor_uk
update phoned aor to get it set up they do not work on 2002 to old i was told
But he told me how to do it just with screwdriver
take top bottom off
set radio to a freq thats broadcast so chose local volmet with the 10k out
put radio to proper freq signal voice gone tuned t1 bottom of board till voice and sig returned tuned for best peak bottom back on
top of board tuned to caps has intructed same has bammouse said
out come radio bacxk on freq working well thanks all for help
was not to worried about it going wrong only cost 36 pound and i have a aor 820 aor 300a
and icom ic r 8500 so pleanty to play with
cheers all
