I purchased a 3000A along with the AOR Searchlight software back in the mid 90's. I uses an IBM Thinkpad that was running Windows 3.1 which worked fine. I now am attempting to get the 3000A and the software to run on a not so old laptop that has XP as its operating system. I have gone into the device manager for the laptop and made the settings of 4800 8 None and 1 to match the software. The RS232 cable is a straight thru as required. The device manager says the laptop RS232 DB9 connector is port 1 which I have set the same in the software of Searchlight. The radio is not responding to the commands. Any suggestions here with what should be working is not. I tried a different cable and no luck. Searchlight boots up just like it did on the other computer using Windows 3.1.
Glenn
Glenn
