AOR 8200 Reaction tune cable
aortech
new york
can anyone assist me in wiring instructions for fabricating an rt-8200 interface cable for the optoelectronics digital scout to the aor 8200mklll. Checked with aor and they are a discontinued item.
morfis
If you get the unterminated cable from AOR then the black (RXD) needs to go to the tip of your jack plug and the ground (Yellow, blue or shield) to the ring.
If you use an HP journada cable (cheaper in the USA) then the colours will be different but should be easy enough to work out using a multimeter and the table in the 8200 manual that details the connections.
