The 'wall wort" power supply for an AR8600 MK2 is an SRP1201500P 12v 1500mA type. I think this is also used with the AR-DV1.
This power supply results in QRM / noise across the HF band...not only with the AR8600 BUT also with other HF receivers plugged into adjacent sockets!!
Why does AOR supply noisy switch mode power supplies with its radios?
How hard is it to build a switch mode power supply which is quiet? How is saving a few $ on missing out RFI suppressions caps etc in the power supply going to help AOR?
Switch mode power supplies can be built so that they are RF quiet...although I guess it may be better to use a traditional linear power supply.
I have previously checked out a number of switch mode power supplies with my Yaesu FT817. I found a small 12v 3A "laptop type" which I got at a junk sale for $1 (and used with Christmas lights...go figure) is RF quiet across the HF bands..so it can be done
My Samlex and Astron switch mode power supplies are also RF quiet...although the Samlex is a Euro version which has additional RFI suppression caps installed to meet EU regulations...I'm not sure whether the North American version is still missing the caps...but they should be installed as standard
I also have a small REGULATED linear "wall wort" 12v 800mA power supply which should be OK as the AR8600 current consumption according to the specs is a nominal 350mAh. BEWARE that most small LINEAR (ie NOT noisy switch mode) "wall wort" type power supplies are NOT regulated...so if the voltage is measured with no load it will NOT be 12v but something like 16-18v!!
What does anybody else use with an AR8600? Is there an original AOR power supply which is RF quiet?
