AOR SR2000A - Consumer Edition
Mickel1138
Nerd Debonair
Alabama
Approved by the FCC today is the AOR SR2000A FFT Frequency Monitor ‘Consumer Edition’ which has the cellular band blocked. This means regular consumers in the US can now buy an own the SR2000A!
More info here: http://blog.big-dutch.com/?p=114
No clue if it's there might be a MOD? I kid!
Mickel (Big-Dutch himself)
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
This looks like a combination of an AR5000 and an SDU5600. I owned an SDU5600 for a VERY short period of time. It was slow and horrible for weak signals. I returned it. The AR5000 is a great receiver though, to be certain. The SR2000A boasts video reception which of course will be useless for TV after 2/09.
If you've got that much money to spend, why not spend a little more and get what is no doubt a MUCH better setup, such as an AR5000 and an SDR-14 for spectrum display. Great combination.
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
I played with the SR2000A at Dayton and it was a slick setup. In the end, I really wanted something for HF so I ended up actually getting a 5000 and an SDR-14 (which will be arriving soon).
But, the SR2000A was very impressive, very fast, and really showed band activity around Dayton with all the people and radios. Also don't forget that the TV reception feature would be fantastic for 2.4Ghz video cameras.
Shortwavewave
Is it a "freq. monitor" or can it still be used as a reagular radio?? IF so I wish It was avalible back when I bought my R75, and the video output is great.
KC1UA
You will absolutely love the performance of the SDR-14 as a panadapter. Interfaced with the AR5000 and using Spectravue software it's unbeatable for the price. It is phenomenal with weak signals and incredibly fast. You can pick out weak signals that the radio won't even hear. It was just the opposite with the SDU-5600 I had. Unless AOR made some significant improvements between that unit and the 2000 it just will not see weak signals. And, as you state the SDR-14 is a pretty unique HF receiver as well. The only downside of the SDR-14 is the PC based display and the fact that it is a resource hog, especially when running in full screen mode. It needs a PC with plenty of horsepower.
It would be neat if it could be upgraded to receive off-air HDTV signals. I just don't see a lot of usefulness for it with regards to monitoring cameras at 2.4 GHz or 900 MHz.
Also, to view a wide chunk of spectrum, a wider RBW would have to be used to maximize speed of the sweep, which to a point defeats viewing narrow band land mobile signals.
vince48
Central Valley, CA.
I too have the combination of AOR 5000+3 and SDR-14 that was recommended by Scott. It is a great combination. I really can dig out weak signals on 20 meters and 80 meters. Even weak 800mhz signals are monitored with Spectravue.
I must have plenty of horsepower. I use both SDR-14 and run TrunkPCR at the same time. No problems or latency.
vince48
