AOR SR2000A
airwolfbell222
Central North Carolina
Does anyone own one? If so, when you conduct an FFT search and a results list is populated, if you select one of the frequencies to listen from the list, can you return to the list with the original search results or does the list get erased and you have to run the search again?
Thanks,
Franz
mancow
N.E. Kansas
The list is continuously dynamic. There is no way to go back to them. Once the 32 or whatever slots are filled they recycle.
airwolfbell222
Thanks for the reply.
But lets say you fill up the list with 32 slots and then stop the search.
Can you put one of the freqs found during FFT into the VFO, listen and then return back to the list FFT search list that was paused and will you see the results from that first search when you stopped the search or if you return to FFT mode do the orginal search results get deleted automatically?
I'm only interested in the 225-380mhz portion of the spectrum.
carbineone
The list does not save. The best way to use this unit is with another receiver/scanner to enter the hits that pop up. The unit works really good for picking off active frequencies in the area.
