Al42 said:
I think the modification is to allow the decoder to work with audio input, not to redesign the scanner.
The PCR1000 wikki page here on RadioReference lists the 10.7Mhz mod, which I am very interested in doing since I just received my ARD25.
I have a BC250D and a Pro-2096 digital trunking scanners, but IMHO the PCR1000 would be a better solution once I can decode the APCO P25 IBME signals. I use a software package TrunkPCR and for large trunked systems like the San Diego County RCS system I have not found a better solution than TrunkPCR.
SDCRCS has 1509 listed talk groups and it is so hard come up with a working bank scheme that works well so one can listen to all of the groups that you want to listen to without exceeding the small max number of groups the scanners support.
TrunkPCR supports up to 2000 talkgroups and out of those talkgroups you can chunk them into 23 separate banks which can be clicked on and off with the mouse.
Priority talkgroup based scanning is yet another shortcoming of the digital trunking scanners I own. And since TrunkPCR allows you to set a priority 1-99 to each talkgroup it is the coolest thing in the world to listen to the entire system and have the talkgroups I designate interrupt lower priority talkgroups. I do use an old Pro-2022 with discriminator mod to tune the control channel so that this will work. But this way I never miss high priority traffic.
The other thing that is really cool about using the PCR1000 is that while the TrunkPCR program is running I can monitor the control channel and that will display which radios are talking on which talkgroups in real time. Scanners will not give you that much detail since their visual output is limited.
The ARD25 set me back $404.00 includung shipping and I know I could get another digital scanner for almost that amount, but it is worth it to me to have the extra features that computer controlled trunk tracking yields.
The 10.7Mhz mod looks tricky since I believe it is all surface mount which is tough for me to do, but once I get it working I post on here.
-=Patrick=-
