eggs4lunch1
- Joined
- Dec 4, 2006
- Messages
- 4
I have a new BCD396T and am still learning how to program it properly. I am trying to scan the Apco P25 Simi Valley, California PD frequencies listed here: http://www.radioreference.com/modules.php?name=RR&aid=629
I have programmed all of the P25 frequencies into a new Motorola P25 system in the scanner. I get nothing except that the signal strength meter flashes occasionally showing anywhere from a couple or bars to full signal strength. Even when the signal strength meter shows full strength, the SCANNER DOES NOT STOP ITS SCAN AND I GET NOT AUDIO.
I also programmed these same frequencies into a conventional system as a test. On the conventional system the scanner stops when a strong P25 broadcast is received. I can hear these broadcasts, but the P25 channels sound like the speaker is in the bottom of a well. When I receive a strong signal on the conventional system on a P25 channel, the screen displays "P25" on the 4th line. Sometimes the scan will stop on a weak signal, and I will be able to hear the start of a conversation which is then lost or is very garbled. When this occurs, the scanner sometimes displays "ENC" in place of the "P25."
I have the following settings in the scanner:
CTCSS search off
No channels are locked out
The system is not locked out
Modulation is set to auto
Data skip is off
Channel delay time is 2 seconds
System hold time is 2 seconds
Apco P25 Threshold is set to auto
Group Qkeys are enabled
ID search/scan is set to search
I-call is set to off
Attenuator is off
Mode (Trunk) is set to auto
Alert tone is off
Alert level is set to auto
Status bit is set to ignore
End code is set to ignore
Emergency alert is off
C-CH ONLY is off
The P25 trunk frequencies have been entered
I have not entered any Band Plan. Does this need to be done and if so how?
Any ideas as to what I am doing incorrectly?
Thanks for your help.
CTCSS search off
Data skip is off
Attenuator is off
Alert tone is off
C-CH ONLY is off
