APRS telemetry
mooks
I am using a new Argent Data OTM-3 . The telemetry reports 12.9 battery voltage. The byte value is reported as 521. The manual says that it reports in 1/10V and maximum is 20V and the byte value is 1-256. I don't understand why the value is 521 and from that how it gets a voltage of 12.9.
Telemetry also says the equation values are 0,1,0. How can it report 1/10V with an equation of 0,1,0 shouldn't it be 0,0.1,0 ?
An explanation so I can figure it out would be appreciated.
thanks
Mike VE7SML
AK9R
Staff member
Super Moderator
Central Indiana
Have you asked Argent Data?
mooks
I checked the website and read the Wiki.... although it made sense for the examples they gave,
doesn't seem to work with the data I am getting.
Mike VE7SML
AK9R
Staff member
Super Moderator
Central Indiana
Have you called or emailed Argent Data?
talkpair
Clinton County, MO
Are we sure the telemetry data contains the battery voltage?
From looking at your log, I see what appears to be voltage and temperature reported in the comment section of a position packet.
2020-02-03 06:12:48 CST: VE7SML-1>APOT30,WIDE2-1,qAR,VE7SML-4:T#055,475,100,000,000,000,00000000
2020-02-03 06:14:28 CST: VE7SML-1>APOT30,WIDE2-1,qAR,VE7SML-4:>VE7SML -1 KITCHEN TABLE DIGIPEATER
5144.87N/12429.40W# 11.9V 14C
The third line in the above log is a position packet, which is indicated with an exclamation point as the data type indicator.
