APX 4500/Firecom issue
Radio659
Installed 2 APX 4500 mobiles. one firecom system works fire, one will not transmit but receive thru system is fine.
Both radios programmed the same. Any thoughts? Radio adapter power wire has power.
K4EET
Chaplain
Severn, Maryland, USA
Really not enough details… Could be a bad PTT switch on the mic, failed transmitter, and everything in-between. Are the model numbers identical? What are the model numbers? Exactly the same setup? Etc. What other information can you provide?
Radio659
New install by truck manufacture. Both radios, the one working and one that won TX are AN series APX 4500, both model numbers match.
Works with hand mike, but the 2 headsets' with PTT do not work. Receive thru all 6 headsets is working as it should. Firecom only has one change in the software and that is done to both radios.
WB5UOM
Why not flip radios...see if problem goes away in truck that has the issue,if so then its a radio thing if not then I would flip firecom boxes..
not hard to isolate problem since you have two and one does work.
K7UDZ
I second the "flip radios around, then flip other parts around, until you isolate the issue" - but this makes it sound to me like your vendor did not deliver a working setup per contract, so is this something you can punt back to them? Or did it use to work on delivery and then stopped?
buddrousa
Then as stated above swap parts and see where your failure is.
You have 1 of 2 possible problems. Are these on 2 new pieces of apparatus with factory installs?
1. You have wiring issues.
2. You have a defective interface.
Radio659
One is existing, one is new, installed by truck builder.
Will try swapping out.
Thanks for the help.
