APX 4500 Help
iversm24
Boyertown, PA
Hello all,
I have an APX 4500 UHF radio. After programming it, it transmits and receives just fine but on power startup it automatically enters emergency mode. I know there is an option to have it do this but that box is not checked. Any ideas?
n3obl
ØAES-1024
PA
Is there a plug on the accy port. If so you will need to check to see if the emergency jumper wire is in place.
Tech21
Do you have the accessory plug in place? The jumper is located in the accessory plug.
